Title | Size | Downloads |
About the S5500-SI[EI] Command References-book(chm).zip | 2.71 MB |
About the S5500-SI/EI Command References
Command Reference |
Content |
Fundamentals Command Reference |
Covers the commands for logging in to and setting up the S5500-SI/EI Ethernet Switch. This command reference includes: · CLI configuration commands · Logging in to the switch commands · FTP commands · TFTP commands · File management commands · Configuration file management commands · Upgrading software commands · Device management commands |
IRF Command Reference |
Covers the commands for configuring the H3C proprietary Intelligent Resilient Framework (IRF) technology features. It covers planning the switch roles in the IRF virtual device, connecting the IRF link, and detecting and maintaining the IRF virtual device. |
Layer 2 – LAN Switching Command Reference |
Covers the commands for configuring Layer 2 technologies and features in a LAN switched network. This command reference includes: · Ethernet interface configuration commands · Loopback and null interface configuration commands · MAC address table configuration commands · MAC Information configuration commands · Ethernet Link aggregation configuration commands · Port Isolation configuration commands · MSTP configuration commands · BPDU tunneling configuration commands · VLAN configuration commands · Isolate-User-VLAN configuration commands · Voice VLAN configuration commands · GVRP configuration commands · QinQ configuration commands · VLAN mapping configuration commands · LLDP configuration commands · Service loopback group configuration commands |
Layer 3 – IP Services Command Reference |
Covers the commands for configuring IP addresses, adjusting IP parameters, configuring ARP, DNS, and UDP Helper, and implementing interoperation between IPv4 and IPv6. This command reference includes: · Gratuitous ARP configuration commands · Proxy ARP configuration commands · IP addressing configuration commands · DHCP server configuration commands · DHCP relay agent configuration commands · DHCP client configuration commands · DHCP snooping configuration commands · BOOTP client configuration commands · IPv4 DNS configuration commands · IPv6 DNS configuration commands · IP performance optimization configuration commands · UDP Helper configuration commands · IPv6 basics configuration commands |
Layer 3 – IP Routing Command Reference |
Covers the routing configuration commands. This command reference includes: · IP routing basics configuration commands · Static routing configuration commands · RIP configuration commands · OSPF configuration commands · IS-IS configuration commands · BGP configuration commands · IPv6 static routing configuration commands · RIPng configuration commands · OSPFv3 configuration commands · IPv6 IS-IS configuration commands · IPv6 BGP configuration commands · Routing policy configuration commands · Policy-based routing configuration commands · MCE configuration commands |
IP Multicast Command Reference |
Covers the commands for configuring Layer 2 and Layer 3 multicast services. This command reference includes: · IGMP snooping configuration commands · Multicast VLAN configuration commands · Multicast routing and forwarding configuration commands · MBGP configuration commands · MLD snooping configuration commands · IPv6 multicast VLAN configuration commands · IPv6 multicast routing and forwarding configuration commands · MLD configuration commands · IPv6 PIM configuration commands · IPv6 MBGP configuration commands |
ACL and QoS Command Reference |
Covers the commands for classifying traffic with ACLs, and allocating network resources and managing congestions with QoS technologies to improve network performance and network use efficiency. This command reference includes: · ACL configuration commands · QoS policy configuration commands · Priority mapping configuration commands · GTS and line rate configuration commands · Congestion management configuration commands |
Security Command Reference |
Covers security feature commands. Available security features include identity authentication (AAA), access security (802.1X, MAC authentication, and so on), secure management (SSH), SSL, and attack protection (IP source guard, ARP attack protection, and so on). This command reference includes: · AAA configuration commands · 802.1X configuration commands · EAD fast deployment configuration commands · MAC authentication configuration commands · Portal configuration commands · Port security configuration commands · User profile configuration commands · Password control configuration commands · HABP configuration commands · Public key configuration commands · PKI configuration commands · IPsec configuration commands · SSH2.0 configuration commands · SFTP configuration commands · SSL configuration commands · TCP attack protection configuration commands · IP source guard configuration commands · ARP attack protection configuration commands · ND attack defense configuration commands · URPF configuration commands |
High Availability Command Reference |
Covers high availability commands for managing failure detection and failover. Failure detection technologies focus on fault detection and isolation. Failover technologies focus on network recovery. This command reference includes: · Ethernet OAM configuration commands · CFD configuration commands · DLDP configuration commands · RRPP configuration commands · Smart Link configuration commands · Monitor Link configuration commands · VRRP configuration commands · BFD configuration commands · Stateful failover configuration commands · Track configuration commands |
Network Management and Monitoring Command Reference |
Covers the commands that help you manage and monitor your network, for example, manage system events, collect traffic statistics, assess network performance, synchronize the clock for all devices with the clock in the network, supply power for attached devices by using PoE, perform cluster management for switches, and test network connectivity. This command reference includes: · System maintenance and debugging commands · Cluster management configuration commands · Port mirroring configuration commands · Traffic mirroring configuration commands · sFlow configuration commands · Information center configuration commands · Stack management configuration commands |
